Länk med paranteser
Startat av Ozp, 14 april 2021 kl. 08:55:07
http://www.test.com
http://www.test.com
http://www.test.com
http://www.test.com
http://www.test.com
http://www.test.com
example.biz
www.example.info
ftp://user:password@ftp.example.com
ftp://ftp.is.co.za/rfc/rfc1808.txt
gopher://spinaltap.micro.umn.edu/00/Weather/California/Los%20Angeles
http://www.math.uio.no/faq/compression-faq/part1.html
mailto:mduerst@ifi.unizh.ch
news:comp.infosystems.www.servers.unix
telnet://melvyl.ucop.edu/
foobar//www.example.com
http://høns.dk
http://ar.wikipedia.org/wiki/النطاقات_العربية
http://example.com/foo_(bar_baz)
(http://example.com/foo_bar_baz)
http://example.com/(bar_(qux)_baz)_(foo)?test=test;foo=bar
example.com/?test=[(foo)]{bar}
http://www.example.com/a/test?one=for#{all"
http://www.example.com/a/test?one=for<all>#derp
mailto:jsmith@example.com?subject=A%20Test&body=My%20idea%20is%3A%20%0A
file:///Users/foo/bar.txt
http://example.com/
http://example.com//
http://example.com/foo.php?
foo://bar
facetime://+19995551234
Have you been to example.com? It is exemplary!
Have you been to example.com?It is exemplary!
Have you been to //example.com?It is exemplary!
Have you been to http://example.com?It is exemplary!
http://123.4.56.78/
https://[2001:db8:85a3:8d3:1319:8a2e:370:7348]:443/foo.html
http://[::1]/foo.html
//foo.asghetyh
//foo.com
qwer:111
ssh://localhost
ssh://toaster.local
ssh:111
mailto:mduérst@ifi.unizh.ch
jsmith@example.com
For an example of a valuably variable foo, go to http://www.example.com/index.php?var[foo]=value!
Have you been to http://www.example.com/index.php?var[foo]=value?
In parentheses (http://www.example.com/index.php?var[foo]=value), will this still be autolinked correctly?
What about in brackets [http://www.example.com/index.php?var[foo]=value]?
http://www.test.com
http://www.test.com
http://www.test.com
http://www.test.com
http://www.test.com
http://www.test.com
http://www.test.com
http://www.test.com
http://www.test.com
